Einleitung
If you need to replace a Brad Nailer Pressure Regulator Knob, follow the steps outlined in this guide. For this guide, you will need a 2mm Allen wrench. The steps outlined are relatively easy to follow.
Was du brauchst
Using a 2mm Allen wrench, remove the Allen screw located on the pressure regulator knob on the back of the brad nailer.
Fast fertig!
Abschluss
