Einleitung
Replacing the Intel Centrino Wireless Chipset with a component that meets the same standard.
Was du brauchst
Unlock the battery latch on the right.
Unlock the battery lock on the left.
Remove the battery pack from its slot.
Using the Philips # 0 screwdriver, unscrew the 2 screws of the top cover
Check the marks indicating the direction in which the cover must be removed.
Remove the bottom cover by removing it in the direction of the markers.
Here is the WLAN Chipset / Bluetooth
Gently unplug the MAIN and AUX antennas.
Unscrew the fixing screw with Philips # 0 screwdriver.
Slightly lift the chipset and remove it from the mSATA connector.
Here is the chipset outside of its location.
To reassemble your device follow the following instructions in reverse order
100%
irlanda hilft uns, die Welt in Ordnung zu bringen! Wie kann ich mithelfen?
Hier starten ›
