Zum Hauptinhalt wechseln
Wacom Cintiq 24HD Power Button Replacement
Was du brauchst
  1. Wacom Cintiq 24HD Power Button Replacement, Stand: Schritt 1, Bild 1 von 1
    • Unplug any cables from the USB, power, display or DVI-D ports by gripping the cord by the connector and pulling straight out of the port.
    • Unplugging the cables by pulling on the cord or pulling at an angle can damage the cable or connector.
  2. Wacom Cintiq 24HD Power Button Replacement: Schritt 2, Bild 1 von 3 Wacom Cintiq 24HD Power Button Replacement: Schritt 2, Bild 2 von 3 Wacom Cintiq 24HD Power Button Replacement: Schritt 2, Bild 3 von 3
    • Place the device screen down on a flat surface.
    • Remove eight 10mm Phillips #2 screws (four on each leg of the stand) by turning the screwdriver counterclockwise.
  3. Wacom Cintiq 24HD Power Button Replacement: Schritt 3, Bild 1 von 1
    • Lift the stand up and away from the rest of the device so the legs separate from the mounting plate.
  4. Wacom Cintiq 24HD Power Button Replacement, Back Panel: Schritt 4, Bild 1 von 3 Wacom Cintiq 24HD Power Button Replacement, Back Panel: Schritt 4, Bild 2 von 3 Wacom Cintiq 24HD Power Button Replacement, Back Panel: Schritt 4, Bild 3 von 3
    • Remove eighteen 10.2mm Phillips #1 screws from the perimeter of the back panel by turning the screwdriver counterclockwise.
    • Remove one 11.9mm Phillips #1 screw from the center of the back panel.
    • Remove two 10.2mm Phillips #1 screws from underneath hinged panels in the bottom right and left corners.
    • Our device does not include the cover panels for the USB, DVI-D, and power ports. You must first remove these cover panels shown in green in order to remove the back panel.
  5. Wacom Cintiq 24HD Power Button Replacement: Schritt 5, Bild 1 von 2 Wacom Cintiq 24HD Power Button Replacement: Schritt 5, Bild 2 von 2
    • Lift the back panel up by a corner and insert a plastic opening tool in the gap.
    • Slide the tool along the gap around the perimeter of the device while lifting to unlatch the back panel.
    • The latches on the back panel will make loud clicking noises when opening.
    • Remove the panel by lifting it up and off of the device.
  6. Wacom Cintiq 24HD Power Button Replacement, Power Button: Schritt 6, Bild 1 von 2 Wacom Cintiq 24HD Power Button Replacement, Power Button: Schritt 6, Bild 2 von 2
    • Remove the rubber cover on the power button by lifting up and off.
  7. Wacom Cintiq 24HD Power Button Replacement: Schritt 7, Bild 1 von 1
    • Remove the two 9.5mm Phillips #2 screws by turning the screwdriver counterclockwise.
  8. Wacom Cintiq 24HD Power Button Replacement: Schritt 8, Bild 1 von 2 Wacom Cintiq 24HD Power Button Replacement: Schritt 8, Bild 2 von 2
    • Remove the cable connected to the button board by pinching close to the connector and pulling the wiring straight out from the port.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Jay Sung
481 Reputation
4 Anleitungen geschrieben
Cal Poly, Team S15-G3, White Fall 2018 Mitglied von Cal Poly, Team S15-G3, White Fall 2018
CPSU-WHITE-F18S15G3
4 Mitglieder
18 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 10
Letzte 30 Tage: 25
Insgesamt: 1,710
