Einleitung
DTU-1031X is a fairly easy device to disassemble. The most challenging part of the disassembly process is detaching the bottom plastic cover secured with quite large plastic clips.
The display is not glued to the front glass.
All internal parts are held together with common phillips screws.
Was du brauchst
Place the tablet with the screen facing down the surface.
(Optional) Remove the plastic dummy plug in the pen holder
To remove the USB daughter board, unscrew 3 Philips #00 screws
Disconnect the cable and remove the board
To remove the mainboard, unscrew 4 Phillips #00 screws
Unplug the 40-pin LVDS flex cable
Unplug two cables connecting the digitizer daughter board to mainboard
Unplug the USB daughter board cable
To remove the digitizer daughter board, unscrew 4 Phillips #00 screws
Unclip two flex cables connecting the digitizer to the digitizer board
Disconnect two cables connecting the daugher board with the mainboard
Unplug the 40-pin LVDS cable from the LCD display
Unscrew 11 Phillips #00 screws holding the metal piece to the front plastic casing
Unscrew 9 wide Phillips #00 screws holding the LCD panel to the front plastic casing
The LCD display will now be loose, and can be removed
