Einleitung
The Wacom Intuos4s touch ring is useful for navigating your computer quickly. If the keys become loose, damaged or otherwise work improperly this guide will help you fix them.
This guide was created with a model PTK-640 Wacom Intuos4. Different models may vary in design.
Was du brauchst
Flip device on its back and remove all fourteen 7.1 mm screws using a Phillips #1 screwdriver.
There is a single screw located under each of the rubber leg pieces. Use a shimmy tool to remove these pieces to access the screws.
Lift the screen's foam backing connecting the motherboard/drawing board to the two smaller express-key boards, placing it onto the motherboard.
Separate the outer casing from the rest of the tablet.
Lift the black plastic clip holding the flat wire to the connector with either tweezers or an iFixit opening tool.
Pull on the white plastic tab to disconnect the flat wire.
Remove the plastic tracking ball by lifting it up and out of its slot.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
