Einleitung
The motor drives the clipper blades. Motors can wear out after extended use. Replacing a worn-out motor can extend the longevity of this device.
Was du brauchst
Remove the three 9.0 mm JIS #1 screws attaching the base of the blade assembly to the body.
Remove the 13.0 mm Phillips #2 screw on the side of the device body.
This screw is located on the opposite side of the body from the switch.
Remove the spring on the side of the body using tweezers.
2 weitere Personen haben diese Anleitung absolviert.
