Zum Hauptinhalt wechseln
Wahl Chrome Pro Motor Replacement
Was du brauchst
  1. Wahl Chrome Pro Motor Replacement, Case: Schritt 1, Bild 1 von 1
    • Remove the two 5.0 mm JIS #1 screws to loosen the cutting blades.
    • Make sure your device is not connected to power before you begin.
  2. Wahl Chrome Pro Motor Replacement: Schritt 2, Bild 1 von 1
    • Lift the bottom blade straight up from the device body to remove it.
  3. Wahl Chrome Pro Motor Replacement: Schritt 3, Bild 1 von 1
    • Remove the three 9.0 mm JIS #1 screws attaching the base of the blade assembly to the body.
  4. Wahl Chrome Pro Motor Replacement: Schritt 4, Bild 1 von 1
    • Lift the base of blade assembly straight up off of the body.
  5. Wahl Chrome Pro Motor Replacement: Schritt 5, Bild 1 von 1
    • Remove the two 12.0 mm JIS #1 screws on the back of the device body.
  6. Wahl Chrome Pro Motor Replacement: Schritt 6, Bild 1 von 1
    • Remove the 13.0 mm Phillips #2 screw on the side of the device body.
    • This screw is located on the opposite side of the body from the switch.
  7. Wahl Chrome Pro Motor Replacement: Schritt 7, Bild 1 von 1
    • Remove the spring on the side of the body using tweezers.
  8. Wahl Chrome Pro Motor Replacement: Schritt 8, Bild 1 von 1
    • Pry the body case off of the device using a spudger.
  9. Wahl Chrome Pro Motor Replacement, Motor: Schritt 9, Bild 1 von 1
    • Lift power cord tab (black wire) from slot on motor base.
  10. Wahl Chrome Pro Motor Replacement: Schritt 10, Bild 1 von 1
    • Lift switch tab (teal wire) from slot on motor base.
  11. Wahl Chrome Pro Motor Replacement: Schritt 11, Bild 1 von 1
    • Remove two 23.0 mm JIS #1 screws attaching motor base to device body.
  12. Wahl Chrome Pro Motor Replacement: Schritt 12, Bild 1 von 1
    • Lift motor base straight up from device body to remove.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Ashley Dale
285 Reputation
2 Anleitungen geschrieben
IUPUI, Team S7-G3, Baechle Fall 2017 Mitglied von IUPUI, Team S7-G3, Baechle Fall 2017
IUPUI-BAECHLE-F17S7G3
3 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 5
Letzte 30 Tage: 14
Insgesamt: 1,242
