Was du brauchst
Refer to the 4th step in disassemble process to begin replacement of motor.
In this step focus on the motor, ignoring the chip set and battery. Here you will be able to remove the motor from the wires.
After the wires are removed and the motor is detached use the replacement motor you purchased and reconnect the wires.
Eine weitere Person hat diese Anleitung absolviert.
Ein Kommentar
Did you actually find this motor (or an equivalent) for sale? Where?
