Zum Hauptinhalt wechseln
Wahl Lithium Ion Trimmer Slide switch Replacement
  1. Wahl Lithium Ion Trimmer  Slide switch Replacement, Slide switch: Schritt 1, Bild 1 von 1
    • Start at the last step of the disassembly guide.
  2. Wahl Lithium Ion Trimmer  Slide switch Replacement: Schritt 2, Bild 1 von 1
    • remove the inside on the razor which includes the chip set, battery, motor and switch.
  3. Wahl Lithium Ion Trimmer  Slide switch Replacement: Schritt 3, Bild 1 von 1
    • focus on the chip set and the white piece on top. The white piece is the switch that turns the razor on and off.
  4. Wahl Lithium Ion Trimmer  Slide switch Replacement: Schritt 4, Bild 1 von 1
    • Remove the white piece. Be careful doing so because the chip set is delicate and breaking that would result in replacing that as well.
  5. Wahl Lithium Ion Trimmer  Slide switch Replacement: Schritt 5, Bild 1 von 1
    • Upon removing the switch, exchange the broken part with the new one that you bought and replace it. Once installed put the razor back together and now you will be able to turn the razor on and off.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
nathan
1.422 Reputation
6 Anleitungen geschrieben
University of Maryland, Team 1-3, Shastany Fall 2013 Mitglied von University of Maryland, Team 1-3, Shastany Fall 2013
UMD-SHASTANY-F13S1G3
3 Mitglieder
12 Anleitungen geschrieben
Ein Kommentar
Where can you source this part from?
John - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 17
Letzte 30 Tage: 33
Insgesamt: 3,436
