Einleitung
In this guide you will learn how to replace the chip set in a Wahl Lithium Ion Trimmer.
Was du brauchst
Begin by removing the rubber grip along the handle.
Pry open the plastic cover into two separate pieces. The plastic is very durable so don't worry about breaking it upon prying it open.
Remove the motor, battery, and motherboard from the plastic casing.
Remove the old motherboard and install the new one. Then, connect the wires and white piece to the new motherboard.
