Einleitung
Use this guide to replace the blade on your device.
Was du brauchst
Unscrew the two 3.8 mm Phillip head screws located on the blade using a Phillip's #0 screwdriver.
Unscrew the 6.2 mm Phillip head screw using a Phillip's #1 screwdriver and remove the blade.
3 weitere Personen haben diese Anleitung absolviert.
