Einleitung
Use this guide to replace the motor of your Wahl Professional Designer.
Was du brauchst
Unscrew the 12 mm Phillips head screws located at the top of the cover and at the bottom two corners, using a Phillips #1 Screwdriver.
Remove the wires connected to the motor by firmly grasping both sides of a wire and wiggling until it is released.
Unscrew the two 20.5 mm Phillip head screw located on the motor using a Phillip's #1 screwdriver.
Eine weitere Person hat diese Anleitung absolviert.
