Einleitung
In this guide you will learn, step-by-step, how to open the Waka Waka Power Plus and remove the battery.
Was du brauchst
Lay device so power button is facing up.
Lift the plastic cover from the center of the device.
You now separated the black part containing the battery and the yellow case.
Remove the springs and their white casings to easily reach the battery.
Replacement batteries can be found online. After placing in the new battery reassemble your device, follow these instructions in reverse order.
2 weitere Personen haben diese Anleitung absolviert.
