Zum Hauptinhalt wechseln
Wand Company Star Trek Communicator Antenna Grille Replacement
Was du brauchst
  1. Wand Company Star Trek Communicator Antenna Grille Replacement, Antenna Grille: Schritt 1, Bild 1 von 1
    • Power off the Star trek Bluetooth Communicator before disassembling by holding down the left button for five seconds. A "woosh-down" sound indicates the power is going off, and no lights will blink.
  2. Wand Company Star Trek Communicator Antenna Grille Replacement: Schritt 2, Bild 1 von 2 Wand Company Star Trek Communicator Antenna Grille Replacement: Schritt 2, Bild 2 von 2
    • Remove the four T6 Torx screws (1.70mm) located on the back of the device.
    • Remove the black plastic cover by gently pulling it.
  3. Wand Company Star Trek Communicator Antenna Grille Replacement: Schritt 3, Bild 1 von 2 Wand Company Star Trek Communicator Antenna Grille Replacement: Schritt 3, Bild 2 von 2
    • Remove the protective foam located around the speaker and charging magnets.
    • Be careful not to lose the two magnets located between the microphone and the speaker. The magnets can be easily removed if they come in contact with other magnetic materials. Use non-magnetic tools if possible.
  4. Wand Company Star Trek Communicator Antenna Grille Replacement: Schritt 4, Bild 1 von 1
    • Remove the two Phillips PH0 (0.9mm) screws located to the side of each magnet.
  5. Wand Company Star Trek Communicator Antenna Grille Replacement: Schritt 5, Bild 1 von 1
    • Remove the black cover.
    • Do not try to completely separate the black cover from the rest of the device since there are thin wires attached to the speaker and microphone.
  6. Wand Company Star Trek Communicator Antenna Grille Replacement: Schritt 6, Bild 1 von 1
    • Remove the protective foam attached to the battery.
    • The protective foam may be adhered to the underside of the plastic cover.
  7. Wand Company Star Trek Communicator Antenna Grille Replacement: Schritt 7, Bild 1 von 2 Wand Company Star Trek Communicator Antenna Grille Replacement: Schritt 7, Bild 2 von 2
    • Remove the five Phillips PH0 (0.9mm) screws located at the top and bottom of the silver plate. The three upper screws are different lengths and gauge than the lower two.
  8. Wand Company Star Trek Communicator Antenna Grille Replacement: Schritt 8, Bild 1 von 1
    • Remove the silver plate.
    • Carefully pivot and/or flip the midplate so as not to put stress on the thin wires. You can gently seat the miplate onto the plastic cover to keep them together securely.
    • Be careful not to lose the two hinge pins with plastic sleeves, located on the outer hinges of the antenna grill. If removed from their location, put them gently back into place. They must be positioned properly before the steel midplate is put back in place.
  9. Wand Company Star Trek Communicator Antenna Grille Replacement: Schritt 9, Bild 1 von 1
    • Remove the antenna grill.
    • Be careful of the plastic "brake" sleeve that mates with a triangular protrusion on the hinge spindle. The brake sleeve is spring-loaded, and is what gently holds the antenna in the open or closed position.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
hans flores
138 Reputation
1 Anleitung geschrieben
USF Tampa, Team 5-6, Passmore Spring 2017 Mitglied von USF Tampa, Team 5-6, Passmore Spring 2017
USFT-PASSMORE-S17S5G6
4 Mitglieder
3 Anleitungen geschrieben
3 Kommentare
Really?!
I tried this tonight and I now have a bag of useless components. You made no mention of the SPRING on the antenna grille which flew off on removal of the grille and then I had no idea which way it was located on re-assembly. I guessed the orientation then couldn’t get the metal plate to fit back on. That led to me snapping one of the hair thin wires! I now have £120 of junk components. Thanks a lot!
Phil - Antwort
Where can we get a replacement grille?
Matthew Campbell - Antwort
I know this post is more than a year old, but I was able to contact the Wand Company and purchase a replacement grille from them.
gschyve -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 14
Insgesamt: 1,181
