Einleitung
This detailed guide will cover the particulars on how to replace the Antenna Grille in the event it becomes damaged or does not open.
Was du brauchst
Power off the Star trek Bluetooth Communicator before disassembling by holding down the left button for five seconds. A "woosh-down" sound indicates the power is going off, and no lights will blink.
Remove the four T6 Torx screws (1.70mm) located on the back of the device.
Remove the black plastic cover by gently pulling it.
Remove the five Phillips PH0 (0.9mm) screws located at the top and bottom of the silver plate. The three upper screws are different lengths and gauge than the lower two.
Remove the silver plate.
Carefully pivot and/or flip the midplate so as not to put stress on the thin wires. You can gently seat the miplate onto the plastic cover to keep them together securely.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
3 Kommentare
Really?!
I tried this tonight and I now have a bag of useless components. You made no mention of the SPRING on the antenna grille which flew off on removal of the grille and then I had no idea which way it was located on re-assembly. I guessed the orientation then couldn’t get the metal plate to fit back on. That led to me snapping one of the hair thin wires! I now have £120 of junk components. Thanks a lot!
Where can we get a replacement grille?
I know this post is more than a year old, but I was able to contact the Wand Company and purchase a replacement grille from them.
gschyve -
