Einleitung
This detailed guide will cover the particulars on how to replace the middle Silver Plate in the event that it becomes damaged or bent.
Was du brauchst
Power off the Star trek Bluetooth Communicator before disassembling.
Remove the four T6 Torx screws (1.70mm) located on the back of the device.
Remove the black plastic cover by gently pulling it.
Remove the five Phillips PH0 (0.9mm) screws located at the top and bottom of the silver plate.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
