Zum Hauptinhalt wechseln
Waring 51BL29 Motor Replacement
Was du brauchst
  1. Waring 51BL29 Motor Replacement, Bottom Panel: Schritt 1, Bild 1 von 2 Waring 51BL29 Motor Replacement, Bottom Panel: Schritt 1, Bild 2 von 2
    • Turn the blender on its side so the bottom panel is facing you.
    • Unscrew the 22mm Phillips #1 screw on the indent of the panel.
    • Unscrew the 3 screws in the rubber holes.
  2. Waring 51BL29 Motor Replacement: Schritt 2, Bild 1 von 1
    • Remove the bottom panel.
  3. Waring 51BL29 Motor Replacement, Drive Coupling: Schritt 3, Bild 1 von 1
    • Place the screwdriver in the head of the middle flat-head screw.
  4. Waring 51BL29 Motor Replacement: Schritt 4, Bild 1 von 1
    • Unscrew this screw while holding the coupling with your other hand and not allowing it to rotate.
    • This screw may be reverse-threaded.
  5. Waring 51BL29 Motor Replacement: Schritt 5, Bild 1 von 1
    • Once the coupling mechanism has been loosened all the way, gently pull it off the top of the blender.
  6. Waring 51BL29 Motor Replacement, Motor: Schritt 6, Bild 1 von 2 Waring 51BL29 Motor Replacement, Motor: Schritt 6, Bild 2 von 2
    • Unscrew the four nuts in the bottom of the motor cavity.
    • Wiggle the motor until it is free and you can remove it.
  7. Waring 51BL29 Motor Replacement: Schritt 7, Bild 1 von 1
    • Once motor is pulled out, unscrew the 8 mm screw for the green wire from the base of the blender.
  8. Waring 51BL29 Motor Replacement: Schritt 8, Bild 1 von 3 Waring 51BL29 Motor Replacement: Schritt 8, Bild 2 von 3 Waring 51BL29 Motor Replacement: Schritt 8, Bild 3 von 3
    • Unscrew each white wire cap in order to free the motor from the power cord.
    • Once wire caps are removed, separate wires carefully.
Abschluss
Dean Becker
470 Reputation
4 Anleitungen geschrieben
Cal Poly, Team S15-G4, Banghart Spring 2017 Mitglied von Cal Poly, Team S15-G4, Banghart Spring 2017
CPSU-BANGHART-S17S15G4
4 Mitglieder
5 Anleitungen geschrieben
Ein Kommentar
Hi
Where do I source a replacement motor? I have been looking without success for UK supplier. Thanks Jill
I have a much loved Vintage Waring blender …
Jill Lancaster - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 10
Letzte 30 Tage: 22
Insgesamt: 2,520
