Einleitung
The motor is the main component of the blender underneath the bottom plate. This guide will walk you through how to remove it step-by-step.
Was du brauchst
Turn the blender on its side so the bottom panel is facing you.
Unscrew the 22mm Phillips #1 screw on the indent of the panel.
Unscrew the 3 screws in the rubber holes.
Place the screwdriver in the head of the middle flat-head screw.
Unscrew this screw while holding the coupling with your other hand and not allowing it to rotate.
Once the coupling mechanism has been loosened all the way, gently pull it off the top of the blender.
Unscrew the four nuts in the bottom of the motor cavity.
Wiggle the motor until it is free and you can remove it.
Once motor is pulled out, unscrew the 8 mm screw for the green wire from the base of the blender.
Unscrew each white wire cap in order to free the motor from the power cord.
Once wire caps are removed, separate wires carefully.
Ein Kommentar
Hi
Where do I source a replacement motor? I have been looking without success for UK supplier. Thanks Jill
I have a much loved Vintage Waring blender …
