Zum Hauptinhalt wechseln
Waring Pro SB30 Plastic Leg and Rubber Stoppers Replacement
Was du brauchst
  1. Waring Pro SB30 Plastic Leg and Rubber Stoppers Replacement, Back Panel: Schritt 1, Bild 1 von 1
    • Remove the screws on the back panel with the #1 Phillips screwdriver bit.
    • The screws in the rubber legs of the burner do not need to be removed.
    • If the back panel has never been opened before, the screws may be more difficult to unscrew.
  2. Waring Pro SB30 Plastic Leg and Rubber Stoppers Replacement: Schritt 2, Bild 1 von 2 Waring Pro SB30 Plastic Leg and Rubber Stoppers Replacement: Schritt 2, Bild 2 von 2
    • Using a wrench, remove the bolt from the center of the back panel.
  3. Waring Pro SB30 Plastic Leg and Rubber Stoppers Replacement: Schritt 3, Bild 1 von 1
    • The back panel can now be easily lifted off.
  4. Waring Pro SB30 Plastic Leg and Rubber Stoppers Replacement, Plastic Leg and Rubber Stoppers: Schritt 4, Bild 1 von 2 Waring Pro SB30 Plastic Leg and Rubber Stoppers Replacement, Plastic Leg and Rubber Stoppers: Schritt 4, Bild 2 von 2
    • While using the wrench to hold the bolt, use the screwdriver to remove the screw.
    • The leg is two separate pieces, the plastic leg and rubber stopper.
    • Careful not to lose the bolts and washers as they are very small.
Abschluss
Sun Fai Lau
588 Reputation
5 Anleitungen geschrieben
USF Tampa, Team 10-7, Brown Fall 2014 Mitglied von USF Tampa, Team 10-7, Brown Fall 2014
USFT-BROWN-F14S10G7
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 182
