Zum Hauptinhalt wechseln
Water Tap Perlator Replacement
Was du brauchst
  1. Water Tap Perlator Replacement, Loosen the tread: Schritt 1, Bild 1 von 1
    • Loosen the perlator using some water pump pliers or an appropriate sized wrench.
    • Use some folded up paper shop towel to prevent the pliers scratching up the perlator, if you want to reuse it.
    Frag FixBot
    Kommentar hinzufügen
  2. Water Tap Perlator Replacement, Unscrew the perlator: Schritt 2, Bild 1 von 2 Water Tap Perlator Replacement, Unscrew the perlator: Schritt 2, Bild 2 von 2
    • Unscrew and remove the perlator by hand.
    • When screwing it on again just doing it finger tight will be alright, but you can also tighten it by following step one in reverse.
    Frag FixBot
  3. Water Tap Perlator Replacement, Measure the tread diameter: Schritt 3, Bild 1 von 1
    • Measure the outer diameter of the tread.
    • Common sizes would be M18, M20, M22, M24 and M28, with M24 being the most common of the bunch.
    Frag FixBot
Abschluss
4 weitere Personen haben diese Anleitung absolviert.
Sebastian
33.352 Reputation
72 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 13
Letzte 7 Tage: 90
Letzte 30 Tage: 350
Insgesamt: 7,391
