Zum Hauptinhalt wechseln
Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra
Was du brauchst
Einführungsvideo
    1. Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Heat the right edge: Schritt 1, Bild 1 von 1
      • Heat an iOpener and apply it to the right edge of the back cover for two minutes.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are susceptible to heat damage.
      Frag FixBot
      Kommentar hinzufügen
    2. Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Adhesive information: Schritt 2, Bild 1 von 2 Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Adhesive information: Schritt 2, Bild 2 von 2
      • While you wait for the adhesive to soften, note the following:
      • There's adhesive securing the back cover around the perimeter of the frame.
      • The adhesive is strongest in the bottom right and top left corners.
      Frag FixBot
    3. Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Insert an opening pick: Schritt 3, Bild 1 von 3 Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Insert an opening pick: Schritt 3, Bild 2 von 3 Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Insert an opening pick: Schritt 3, Bild 3 von 3
      • Apply a suction handle to the back cover, as close to the center of the right edge as possible.
      • Pull up on the suction handle with strong, steady force to create a gap between the cover and the frame.
      • If you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
      • Insert an opening pick into the gap.
      Frag FixBot
    4. Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Separate the right adhesive: Schritt 4, Bild 1 von 3 Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Separate the right adhesive: Schritt 4, Bild 2 von 3 Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Separate the right adhesive: Schritt 4, Bild 3 von 3
      • Slide the pick back and forth along the right edge to separate the adhesive.
      • Leave the pick inserted near the bottom right corner to prevent the adhesive from resealing.
      Frag FixBot
    5. Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Heat the bottom edge: Schritt 5, Bild 1 von 1
      • Apply a heated iOpener to the bottom edge of the back cover for two minutes.
      Frag FixBot
    6. Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Separate the corner adhesive: Schritt 6, Bild 1 von 3 Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Separate the corner adhesive: Schritt 6, Bild 2 von 3 Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Separate the corner adhesive: Schritt 6, Bild 3 von 3
      • Insert a second opening pick at the bottom right corner.
      • Angle the pick upward to match the curved edge and rotate it around the bottom right corner.
      • Be careful while working around the corners, as the glass is very fragile here. Work slowly to avoid cracking the glass.
      Frag FixBot
    7. Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Separate the bottom adhesive: Schritt 7, Bild 1 von 2 Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Separate the bottom adhesive: Schritt 7, Bild 2 von 2
      • Slide your opening pick to the bottom left corner to separate the adhesive.
      • Leave the pick in the bottom left corner to prevent the adhesive from resealing.
      Frag FixBot
    8. Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Heat the left edge: Schritt 8, Bild 1 von 1
      • Apply a heated iOpener to the left edge of the back cover for two minutes.
      Frag FixBot
    9. Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Separate the corner adhesive: Schritt 9, Bild 1 von 3 Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Separate the corner adhesive: Schritt 9, Bild 2 von 3 Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Separate the corner adhesive: Schritt 9, Bild 3 von 3
      • Insert a third opening pick at the bottom left corner.
      • Angle the pick upward to match the curved edge and rotate it around the bottom left corner.
      Frag FixBot
    10. Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Separate the left adhesive: Schritt 10, Bild 1 von 3 Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Separate the left adhesive: Schritt 10, Bild 2 von 3 Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Separate the left adhesive: Schritt 10, Bild 3 von 3
      • Slide your opening pick along the left edge to separate the adhesive, stopping when you reach the power button.
      • Only insert the pick up to 5 mm, as you may damage the antenna flex cable or the power button cable.
      • Leave the pick in the left edge to prevent the adhesive from resealing.
      Frag FixBot
    11. Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Heat the top edge: Schritt 11, Bild 1 von 1
      • Heat an iOpener and apply it to the top edge of the back cover for two minutes.
      Frag FixBot
    12. Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Separate the corner adhesive: Schritt 12, Bild 1 von 3 Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Separate the corner adhesive: Schritt 12, Bild 2 von 3 Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Separate the corner adhesive: Schritt 12, Bild 3 von 3
      • Insert an opening pick in the gap at the top right edge.
      • Angle the pick upward to match the curved edge and rotate it around the top right corner.
      Frag FixBot
    13. Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Separate the top adhesive: Schritt 13, Bild 1 von 2 Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Separate the top adhesive: Schritt 13, Bild 2 von 2
      • Slide the pick to the top left corner to separate the adhesive.
      • Only insert the pick up to 4 mm, as you may damage the cameras or sensors.
      • Leave the pick in to prevent the adhesive from resealing.
      Frag FixBot
    14. Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Separate the corner adhesive: Schritt 14, Bild 1 von 2 Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Separate the corner adhesive: Schritt 14, Bild 2 von 2
      • Insert an opening pick in the gap at the top left edge.
      • Only insert the pick up to 4 mm, as you may damage the cameras.
      • Angle the pick upward to match the curved edge and rotate it around the top left corner.
      Frag FixBot
    15. Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Separate the remaining adhesive: Schritt 15, Bild 1 von 2 Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Separate the remaining adhesive: Schritt 15, Bild 2 von 2
      • Slide the pick toward the bottom camera to separate through the remaining adhesive, stopping before you reach the power button.
      Frag FixBot
    16. Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Remove the back cover: Schritt 16, Bild 1 von 3 Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Remove the back cover: Schritt 16, Bild 2 von 3 Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Remove the back cover: Schritt 16, Bild 3 von 3
      • Grab and remove the back cover.
      • If your cover is still sticking to the frame, slide an opening pick around the perimeter until the cover completely separates.
      • During reassembly:
      • This is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
      • Remove any adhesive chunks with a pair of tweezers or your fingers. Apply heat if you're having trouble separating the adhesive.
      • If you're using custom-cut adhesives, follow this guide.
      • If you're using double-sided tape, follow this guide.
      Frag FixBot
    1. Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Disconnect the NFC antenna and charging coil: Schritt 17, Bild 1 von 3 Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Disconnect the NFC antenna and charging coil: Schritt 17, Bild 2 von 3 Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Disconnect the NFC antenna and charging coil: Schritt 17, Bild 3 von 3
      • Use the pointed end of a spudger to pry up and disconnect the NFC antenna press connector from the motherboard.
      • Repeat for the wireless charging coil press connector.
      • To re-attach press connectors, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down on the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
      Frag FixBot
    2. Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Separate the coil adhesive: Schritt 18, Bild 1 von 3 Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Separate the coil adhesive: Schritt 18, Bild 2 von 3 Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Separate the coil adhesive: Schritt 18, Bild 3 von 3
      • The wireless charging coil is lightly adhered to the battery.
      • Insert an opening pick between the right edge of the wireless charging coil and the battery.
      • Slide the pick along the right edge to separate the adhesive.
      Frag FixBot
    3. Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra: Schritt 19, Bild 1 von 2 Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra: Schritt 19, Bild 2 von 2
      • Insert an opening pick between the top edge of the wireless charging coil and the frame.
      • Slide the pick toward the right edge to separate the remaining adhesive.
      Frag FixBot
    4. Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Unfasten the NFC antenna and charging coil: Schritt 20, Bild 1 von 1
      • Use a Phillips screwdriver to remove the five 3.5 mm-long screws securing the NFC antenna and charging coil.
      Frag FixBot
    5. Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Unfasten the loudspeaker: Schritt 21, Bild 1 von 1
      • Use a Phillips screwdriver to remove the six 3.5 mm screws securing the loudspeaker.
      Frag FixBot
    6. Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Unclip the loudspeaker: Schritt 22, Bild 1 von 2 Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Unclip the loudspeaker: Schritt 22, Bild 2 von 2
      • Insert the pointed end of your spudger between the upper right corner of the loudspeaker and the frame.
      • Pry up to unclip the loudspeaker from the frame.
      • Don't pry against the battery. Use protrusions in the frame for leverage.
      • During reassembly, press around the perimeter of the loudspeaker to clip it to the frame.
      Frag FixBot
    7. Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Remove the charging coil and loudspeaker assembly: Schritt 23, Bild 1 von 3 Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Remove the charging coil and loudspeaker assembly: Schritt 23, Bild 2 von 3 Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Remove the charging coil and loudspeaker assembly: Schritt 23, Bild 3 von 3
      • Grab and remove the NFC, wireless charging coil, and loudspeaker from the frame.
      Frag FixBot
    1. Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Disconnect the battery: Schritt 24, Bild 1 von 2 Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Disconnect the battery: Schritt 24, Bild 2 von 2
      • Use your spudger to pry up and disconnect the battery press connector.
      Frag FixBot
    1. Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Disconnect the interconnect cables: Schritt 25, Bild 1 von 3 Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Disconnect the interconnect cables: Schritt 25, Bild 2 von 3 Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Disconnect the interconnect cables: Schritt 25, Bild 3 von 3
      • Use your spudger to pry up and disconnect the secondary interconnect cable press connector from the motherboard.
      • Repeat for the primary interconnect cable.
      Frag FixBot
    2. Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra: Schritt 26, Bild 1 von 3 Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra: Schritt 26, Bild 2 von 3 Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra: Schritt 26, Bild 3 von 3
      • Use your spudger to pry up and disconnect the secondary interconnect cable press connector from the charging board.
      Frag FixBot
    3. Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Remove the interconnect cables: Schritt 27, Bild 1 von 2 Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Remove the interconnect cables: Schritt 27, Bild 2 von 2
      • Grab and remove the interconnect cables from the frame.
      Frag FixBot
    1. Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Unfasten the charging board: Schritt 28, Bild 1 von 1
      • Use a Phillips screwdriver to remove the three 3.5 mm-long screws securing the charging board.
      Frag FixBot
    2. Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Remove the charging board: Schritt 29, Bild 1 von 3 Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Remove the charging board: Schritt 29, Bild 2 von 3 Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Remove the charging board: Schritt 29, Bild 3 von 3
      • Insert the point of your spudger under the top right of the charging board.
      • Pry the charging board up from its recess until you can grab it with your fingers.
      • Pull the charging board toward the top of the device to remove it from its recess.
      • During reassembly, reinsert the charging board at a downward angle to guide the USB-C port into its recess.
      Frag FixBot
    1. Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Disconnect the earpiece speaker: Schritt 30, Bild 1 von 2 Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Disconnect the earpiece speaker: Schritt 30, Bild 2 von 2
      • Use the point of your spudger to pry up and disconnect the earpiece speaker press connector.
      Frag FixBot
    2. Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Unfasten the motherboard cover: Schritt 31, Bild 1 von 1
      • Use a Phillips screwdriver to remove the five 3.5 mm-long screws securing the motherboard cover.
      Frag FixBot
    3. Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Remove the motherboard cover: Schritt 32, Bild 1 von 3 Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Remove the motherboard cover: Schritt 32, Bild 2 von 3 Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Remove the motherboard cover: Schritt 32, Bild 3 von 3
      • Insert the point of your spudger between the bottom right corner of the motherboard cover and the frame.
      • Pry up on the cover to unclip it from the frame.
      • Remove the motherboard cover.
      • During reassembly, press down on the cover to secure its clips to the frame.
      Frag FixBot
    1. Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Disconnect the front-facing camera: Schritt 33, Bild 1 von 2 Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Disconnect the front-facing camera: Schritt 33, Bild 2 von 2
      • Use the point of your spudger to pry up and disconnect the front-facing camera press connector.
      Frag FixBot
    2. Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Disconnect the fingerprint reader: Schritt 34, Bild 1 von 2 Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Disconnect the fingerprint reader: Schritt 34, Bild 2 von 2
      • Use your spudger to pry up and disconnect the fingerprint reader press connector.
      Frag FixBot
    3. Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Disconnect the screen: Schritt 35, Bild 1 von 2 Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Disconnect the screen: Schritt 35, Bild 2 von 2
      • Use the point of your spudger to pry up and disconnect the screen press connector from the motherboard.
      Frag FixBot
    4. Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra: Schritt 36, Bild 1 von 2 Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra: Schritt 36, Bild 2 von 2
      • Use the point of your spudger to pry up and disconnect the screen press connector from the display cutout near the bottom of the phone.
      Frag FixBot
    5. Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Remove the screen cable: Schritt 37, Bild 1 von 1
      • Grab and remove the screen cable from the frame.
      Frag FixBot
    6. Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Disconnect the right 5G mmWave antenna: Schritt 38, Bild 1 von 2 Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Disconnect the right 5G mmWave antenna: Schritt 38, Bild 2 von 2
      • Use the point of your spudger to pry up and disconnect the right 5G mmWave antenna press connector.
      Frag FixBot
    7. Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Disconnect the stylus: Schritt 39, Bild 1 von 2 Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Disconnect the stylus: Schritt 39, Bild 2 von 2
      • Use the point of your spudger to pry up and disconnect the stylus press connector.
      Frag FixBot
    8. Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Disconnect the left 5G mmWave antenna: Schritt 40, Bild 1 von 2 Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Disconnect the left 5G mmWave antenna: Schritt 40, Bild 2 von 2
      • Use the point of your spudger to pry up and disconnect the left 5G mmWave antenna press connector.
      Frag FixBot
    9. Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Unfasten the motherboard: Schritt 41, Bild 1 von 1
      • Use your Phillips screwdriver to remove the single 4 mm-long screw securing the motherboard.
      Frag FixBot
    10. Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Remove the motherboard: Schritt 42, Bild 1 von 3 Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Remove the motherboard: Schritt 42, Bild 2 von 3 Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Remove the motherboard: Schritt 42, Bild 3 von 3
      • Insert the point of your spudger between the top left of the motherboard and the frame.
      • Pry the motherboard up until you can grab it with your fingers.
      • Grab the motherboard and remove it from the frame.
      • Be careful not to snag any loose cables.
      • During reassembly, make sure the cables are above the motherboard when reinserting it.
      Frag FixBot
    1. Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Heat the front-facing camera: Schritt 43, Bild 1 von 1
      • Heat an iOpener and apply it to the top of the screen for two minutes.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display is susceptible to heat damage.
      Frag FixBot
    2. Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Pry the front-facing camera: Schritt 44, Bild 1 von 3 Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Pry the front-facing camera: Schritt 44, Bild 2 von 3 Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Pry the front-facing camera: Schritt 44, Bild 3 von 3
      • The adhesive securing the camera is very strong. Work slowly and apply more heat if the camera feels stuck. Avoid separating the circuit board from camera housing, such as this.
      • Use the flat end of your spudger to pry the front-facing camera from its recess.
      • If the camera doesn't loosen, use your SIM card eject tool to scrape away the epoxy surrounding the camera.
      Frag FixBot
    3. Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Prepare the new frame: Schritt 45, Bild 1 von 2 Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Prepare the new frame: Schritt 45, Bild 2 von 2
      • During reassembly, prepare your new frame for the front-facing camera:
      • Remove the black adhesive liner from the front-facing camera recess.
      • Peel and remove the foam liner from the new frame.
      • This liner isn't necessary for the repair.
      Frag FixBot
    4. Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Apply new adhesive: Schritt 46, Bild 1 von 3 Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Apply new adhesive: Schritt 46, Bild 2 von 3 Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Apply new adhesive: Schritt 46, Bild 3 von 3
      • Before installing the front-facing camera in your new frame, apply new adhesives onto the frame and the camera:
      • Remove the two large clear rectangular liners from the adhesive sheet and place the adhesives on the sides of the camera recess.
      • Remove the liner from the main adhesive piece and place it in the center of the camera recess with its pull tab facing the bottom of the frame.
      • Remove any adhesive residue from the front-facing camera module.
      • Remove the liner from the thin piece of adhesive and place it on the top edge of the camera.
      Frag FixBot
    5. Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Install the front-facing camera: Schritt 47, Bild 1 von 2 Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Install the front-facing camera: Schritt 47, Bild 2 von 2
      • Install the front-facing camera:
      • Remove all four blue adhesive liners from the camera and the frame.
      • Insert the front-facing camera into its recess in the frame and apply pressure to secure it.
      Frag FixBot
    6. Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Unfasten the left 5G mmWave antenna: Schritt 48, Bild 1 von 1
      • Use a Phillips driver to remove the two 2.4 mm‑long screws securing the left 5G mmWave antenna.
      Frag FixBot
    7. Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Remove the left 5G mmWave antenna: Schritt 49, Bild 1 von 3 Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Remove the left 5G mmWave antenna: Schritt 49, Bild 2 von 3 Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Remove the left 5G mmWave antenna: Schritt 49, Bild 3 von 3
      • Grab the left 5G mmWave antenna connector and lift up to separate the bracket from the frame.
      • Remove the antenna.
      Frag FixBot
    8. Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, mmWave antenna reassembly: Schritt 50, Bild 1 von 3 Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, mmWave antenna reassembly: Schritt 50, Bild 2 von 3 Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, mmWave antenna reassembly: Schritt 50, Bild 3 von 3
      • Before reinstalling the lower 5G mmWave antenna, replace the bracket with a new one. If you don't have a new bracket, skip this step.
      • Remove the antenna and connector from the old bracket.
      • Remove the L-shaped adhesive liner from your new bracket.
      • Place the antenna in the bracket's recess with the connector fed underneath the longer screw mount.
      • Remove the thin adhesive liner on the outside of the bracket before installing it in the frame.
      Frag FixBot
    9. Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Remove the right 5G mmWave antenna: Schritt 51, Bild 1 von 3 Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Remove the right 5G mmWave antenna: Schritt 51, Bild 2 von 3 Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Remove the right 5G mmWave antenna: Schritt 51, Bild 3 von 3
      • Insert the flat end of a spudger between the frame and the right 5G mmWave antenna connector.
      • Pry up with the spudger to separate the adhesive.
      Frag FixBot
    10. Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra: Schritt 52, Bild 1 von 2 Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra: Schritt 52, Bild 2 von 2
      • Grab and remove the right 5G mmWave antenna from the frame.
      Frag FixBot
    11. Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Upper 5G mmWave antenna reassembly information: Schritt 53, Bild 1 von 3 Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Upper 5G mmWave antenna reassembly information: Schritt 53, Bild 2 von 3 Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Upper 5G mmWave antenna reassembly information: Schritt 53, Bild 3 von 3
      • Replace the adhesive on the upper 5G mmWave antenna before reinstalling it. If you don't have replacement adhesive, reuse your old one or use custom-cut adhesive.
      • Remove the existing adhesive from the antenna with blunt nose tweezers or your fingers.
      • Remove the clear liner from your new adhesive.
      • Apply the new adhesive to the bottom of the antenna, with its round end farthest from the connector.
      • Remove the green liner from the adhesive before reinstalling the antenna in the frame.
      Frag FixBot
    12. Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Only the screen and battery assembly remains: Schritt 54, Bild 1 von 1
      • You're now left with the screen and battery assembly.
      • Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
      Frag FixBot
    1. Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, General Procedure followed: Schritt 55, Bild 1 von 1
      • I opened, disassembled, and removed everything up to the point of screen removal, which being destructive and not wanting to put a new screen in a device I actually had little hope of even getting the photos off of, I decided not to remove.
      • I had such low expectations that I didn't even take photos of what I found, in retrospect I wish I had. Corrosion was throughout as you can see in the photo, I spent little effort on the screws on the first pass. There was white and blue oxidation even rust on almost all the metal.
      • This photo was taken AFTER the device was working and backed-up when I went back in to do more cleaning.
      Frag FixBot
    2. Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Specific Methods: Schritt 56, Bild 1 von 1
      • Using contact cleaner spray and a soft-bristle toothbrush I cleaned all the corrosion I could, this involved repeatedly spraying (outdoors, with a fan blowing) and gentle brushing of all the parts both those removed and all accessible parts of the frame and all connectors.
      • Then using the softer brush to sweep for debris and 'buff' it a bit. To Everything, all parts and surfaces, especially the connectors and plugs.
      • I did not anticipate success because the corrosion was pretty heavy in spots and present on almost all metal in the device. I would have followed that with high concentration alcohol, but all I had was rubbing alcohol which contains oils and fragrance that are NOT good to use, if you have or can get 90%+ ETOH or Isopropyl, I'd advise you to.
      • You can see the corrosion on the screws before I cleaned them. (I used a HDD magnet under the cover to keep the tiny screws from going walkabout.)
      Frag FixBot
    3. Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Surprise Outcome: Schritt 57, Bild 1 von 1
      • Not expecting anything and wondering to myself whether it would be justifiable to buy a new battery but hoping maybe I could just use the charging cable... (surely the battery was dead, Yes?)
      • After cleaning as well as I could, and letting it dry over night. (reason for the time estimate-Drying time) I reassembled it, and fed it power to see whether I might be able to connect to it via the USB cable or would have to get a battery first...
      • I plugged it into a fast-charge cable from my own phone since I didn't have the owner's cable and turned to another task... a few minutes later I glanced at the phone and saw (photo) that it claimed to be charging...
      • I was very happy to see this as I figured, HA! The screen isn't dead, so probably I can get the photos. But I did not expect that same battery to charge, or for much to actually work...
      Frag FixBot
    4. Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Recovery of Photos and Videos: Schritt 58, Bild 1 von 3 Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Recovery of Photos and Videos: Schritt 58, Bild 2 von 3 Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Recovery of Photos and Videos: Schritt 58, Bild 3 von 3
      • In under 2 Hours the phone had a full charge. (and holding it now at 48+ hours post-rescusitation),
      • I opted, since I was able to side-load an FTP server and install it successfully, to transfer the files that way since that's faster than my USB3.2 ports and since I didn't trust the device to keep working long... I commenced the file transfer and began exploring what did and didn't work...
      • Front Camera. Rear Camera. Work... Wi-Fi, obviously since it was using it now in moving files. Bluetooth also works. Screen is NOT touch sensitive, but the stylus works and I have hope the software might fix it, I hadn't tried that yet because 1. files were still transferring, and, 2 the language is German which I scarce can speak... very scarce!
      • I needed to change the language or get walked through things. I hadn't yet tested the loudspeaker or microphone, since transfering the photos was the priority. Later or just wait to post it until I have the final status. BUT!
      • I was amazed it was working in nearly all respects; all critical ones. After what it went through and how little I actually did... Basically cleaned the corrosion at a gross level, and reassembled it. SO Lesson learned? Sometimes you do get lucky.
      Frag FixBot
    5. Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Cleaning (Reprise): Schritt 59, Bild 1 von 3 Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Cleaning (Reprise): Schritt 59, Bild 2 von 3 Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Cleaning (Reprise): Schritt 59, Bild 3 von 3
      • I should have bought a lottery ticket! DID NOT expect the phone to work... 'HOPED' to recover photos. After the DCIM folder, I did a full backup of the device this I let run overnight
      • After everything was backed up I took it apart to do more cleaning of the connectors, for example these are After the first cleaning and again after repeating the process in hopes of getting that pesky digitizer to work... No joy on that front.
      Frag FixBot
    6. Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Un-screwing-up the screws: Schritt 60, Bild 1 von 1
      • I took all the screws that I had only cursorily cleaned, brought a couple ounces of vinegar to a boil in the microwave and dropped them in. The photo of them bubbling away as the corrosion was eaten away is somewhat blurred by steam from the hot vinegar, though.
      • Then I rinsed them (when the bubbles subsided) in plain water; rinsed again with about 1/2 tsp of sodium bicarbonate (baking soda) stirred in to get rid of any residual acetic acid, another rinse in plain water and dried them. They came out corrosion free, bright and shiny.
      Frag FixBot
    7. Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, No animals were harmed in the production of this Guide: Schritt 61, Bild 1 von 2 Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, No animals were harmed in the production of this Guide: Schritt 61, Bild 2 von 2
      • In the interest of strict accuracy I must mention that I was assisted in this repair in the periodic cleaning of the soft bristle brush. I am unprepared to attribute success or failure to the feline saliva (photo 1)
      • Nor to the feline pheromones applied to the brush from chin and foot glands... Further scientific study would be needed to ascertain the degree, if any of beneficent/deleterious effects.
      Frag FixBot
    8. Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Remaining steps to complete repair: Schritt 62, Bild 1 von 1
      • I took it apart yet a 3rd time when the microphones were still not working to see if cleaning them better would help.
      • ...And yet a 4th time when it occurred to me to check for any obstructions 'inside' the microphones themselves. (one has very muffled; un-usably so, sound) , I found none, but I back-flushed the tubes with contact cleaner (not obstructed, free passage of the spray)
      Frag FixBot
    9. Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Other things that may help: Schritt 63, Bild 1 von 1
      • What remains: replace the charging board with the microphone or get someone with better eyes, steadier hands and better equipment to replace the actual microphones on the board(s).
      • The owner isn't staying long enough for me to order parts, he plans to take it back to the shop in Germany where their estimate for repair was. "Forget it" ...I suspect he intends to make a point thereby... to fix the remaining issues.
      • Other things you can try that might help: Updating the OS, running the microphone diagnostics, reset the digitizer, adjust touch sensitivity, wiping the cache.
      • Last a hard reset, now that the phone is completely backed-up. I don't expect that to work, no software has been changed since it worked fine. I doubt it is a software issue, but that IS the last-ditch not-yet tried step.
      Frag FixBot
    10. Water-Damaged Phone repair/data recovery of Samsung Galaxy S23 Ultra, Wrapping up: Schritt 64, Bild 1 von 1
      • Final lesson learned, This is usable now, bluetooth headset, USB mic, stylus, Bluetooth mouse/keyboard...
      • if you ever used a PPC that required a stylus 'cause the screen was so small, it would be no problem, I think, after you quit automatically trying to use your finger instead of the stylus. (I still use one from time to time as a backup for reading books, though it really needs a new screen too)...
      • Your mileage may vary... (is VERY likely to) but maybe you can recover your data, if nothing else. Good Luck!
      • One final note, I never did try a hard reset because the owner already had plans to replace the device and pass it along to a family member after doing a direct transfer to his new device... He DID plan to try that after the transfer.
      Frag FixBot
Abschluss
Reparatur/Datenrettung eines wasserbeschädigten Samsung Galaxy S23 Ultra To reassemble your device, follow the instructions in the prerequisite Guide in reverse order.
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 23
Letzte 7 Tage: 78
Letzte 30 Tage: 303
Insgesamt: 1,317
