Einleitung
Welcome to our comprehensive guide on rescuing your Samsung Galaxy Grand Prime from water damage! If your Galaxy Grand Prime has taken an unexpected dive and is now experiencing the effects of water exposure, fear not.
This step-by-step guide is primarily designed to help you navigate through the process of reviving your Samsung Galaxy Grand Prime and preventing long-term damage by providing an effective solution for addressing water damage on your device.
Important Tips and Warnings:
Before diving into the restoration process, take note of the following crucial tips and warnings to ensure a safe and successful recovery:
- Turn off your device: Ensure that your device is shut down to avoid electrical mishaps.
- Remove moisture: Clearing any moisture from the outside is crucial to prevent damage and increase the chances of a successful recovery.
External Resources: For additional insights and reference materials, check out the following external resources:
- How to disassemble 📱 Samsung Galaxy Grand Prime SM-G530, Take Apart, Tutorial
- What to do when Samsung smartphone dropped in the water?
Let's get started on fixing your wet Samsung Galaxy Grand Prime. Follow each step closely for the best chance of bringing it back to life. Good luck!
Was du brauchst
Place the phone with its screen facing the work surface
Position the primary back panel towards you
Detach the primary back panel to expose the battery in the secondary back panel
Using a 1.5x25 millimeter Phillips head screwdriver, remove the nine 4mm screws to gain access to the inner circuitry.
Using the 1.5x25 millimeter Phillips head screwdriver, tighten all 9 of the 4mm screws
Align the primary back panel with the secondary back panel, ensuring the Samsung logo is facing outward
Click the panels together and work your way around until all sides are securely attached
When all steps are performed correctly, the phone should power up and work as intended
3 weitere Nutzer:innen haben diese Anleitung absolviert.
