Zum Hauptinhalt wechseln
Weiser Smartcode 10 Touchscreen Electronic Lock Battery Replacement
Was du brauchst
  1. Weiser Smartcode 10 Touchscreen Electronic Lock Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Unlock your door and open it.
    • Make sure the bolt/latch is fully inside the door before you continue.
  2. Weiser Smartcode 10 Touchscreen Electronic Lock Battery Replacement: Schritt 2, Bild 1 von 1
    • Using the Phillips #1 screwdriver, remove the three 8 mm screws on the left, right and bottom side of the cover.
  3. Weiser Smartcode 10 Touchscreen Electronic Lock Battery Replacement: Schritt 3, Bild 1 von 1
    • Take the exterior cover off of the door lock.
  4. Weiser Smartcode 10 Touchscreen Electronic Lock Battery Replacement: Schritt 4, Bild 1 von 2 Weiser Smartcode 10 Touchscreen Electronic Lock Battery Replacement: Schritt 4, Bild 2 von 2
    • Find the battery pack (marked "DOOR" in between two arrows) at the top of the lock.
  5. Weiser Smartcode 10 Touchscreen Electronic Lock Battery Replacement: Schritt 5, Bild 1 von 2 Weiser Smartcode 10 Touchscreen Electronic Lock Battery Replacement: Schritt 5, Bild 2 von 2
    • Slide the battery pack upwards.
    • Turn the pack over to reveal the batteries.
    • Replace the four AA batteries.
  6. Weiser Smartcode 10 Touchscreen Electronic Lock Battery Replacement: Schritt 6, Bild 1 von 1
    • Reinsert the battery pack with the word "DOOR" facing you.
    • Wait until you see a green LED light flashing and/or hear two beeps to indicate working batteries.
    • If there is no green light, repeat steps 5 and 6. Check to see if the batteries are placed correctly or if newer batteries are required.
  7. Weiser Smartcode 10 Touchscreen Electronic Lock Battery Replacement: Schritt 7, Bild 1 von 1
    • Check that the bolt/latch is still inside the door.
    • Take the exterior cover and point the narrow end of the knob to the right.
    • Place the cover on the lock and reinsert the screws.
    • Try not to fasten the screws too tightly as they could get damaged in the process.
  8. Weiser Smartcode 10 Touchscreen Electronic Lock Battery Replacement: Schritt 8, Bild 1 von 2 Weiser Smartcode 10 Touchscreen Electronic Lock Battery Replacement: Schritt 8, Bild 2 von 2
    • To confirm the finished repair, go to the front of the door and place the back of your hand on the touchscreen to activate the keypad.
Abschluss
Congratulations! Make sure to redo this process each year to ensure your device continues to work!
2 weitere Personen haben diese Anleitung absolviert.
York University, Team S1-G7, Melo-Thaiss Summer 2021 Mitglied von York University, Team S1-G7, Melo-Thaiss Summer 2021
YORK-MELO-THAISS-SU21S1G7
1 Mitglied
2 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 19
Letzte 30 Tage: 107
Insgesamt: 10,853
