Einleitung
If your device is over heating you may need to replace your motor fan. This guide will show you how.
Was du brauchst
While pressing the spindle lock button, unscrew the collet nut and remove it along with the brass collet.
To remove the front panel, pry the device apart while holding the device with the other hand.
The fan assembly is attached to the rotor beam, it can be disassembled to change the fan by simply pulling off the pieces.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
