Einleitung
If the device doesn't rotate, the motor could be bad. Use this guide to replace it.
Was du brauchst
While pressing the spindle lock button, unscrew the collet nut and remove it along with the brass collet.
To remove the front panel, pry the device apart while holding the device with the other hand.
Fast fertig!
Abschluss
Ein Kommentar
All very well and good, but it’s impossible to buy the motor parts to replace…
