Einleitung
If your device is not powering on your power cable may be damaged. If it needs to be replaced this guide will show you how.
Was du brauchst
While pressing the spindle lock button, unscrew the collet nut and remove it along with the brass collet.
To remove the front panel, pry the device apart while holding the device with the other hand.
Identify the screws.
Unscrew the two 3mm phillips PH2.
Phillips PH2
Flathead 2.5mm
Fast fertig!
Abschluss
