Einleitung
One possible reason for your device not powering on is a damaged power switch. Use this guide to replace it.
Was du brauchst
While pressing the spindle lock button, unscrew the collet nut and remove it along with the brass collet.
To remove the front panel, pry the device apart while holding the device with the other hand.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
