Einleitung
In this guide, you will learn how to remove the outer casing of the Westcott iPoint Evolution pencil sharpener. Use this guide to replace the casing or to access the sharpener's internal components.
Was du brauchst
Step 2: Grab the end of the plug located at the bottom of the sharpener and pull it out gently.
Step 3: Grab the very top of the sharpener, twist it to the right and lift it up to remove it.
Step 6: Flip the pencil sharpener upside down.
Locate the four screws on the bottom of the sharpener.
Step 8: After all the screws are removed gently take off the bottom of the sharpener.
3 weitere Personen haben diese Anleitung absolviert.
