Einleitung
The mini USB port is needed to access to the data or store new data on the hard drive. In order to attach the mini USB, you will need to know how to solder. When soldering, you run the risk of damaging the board (and yourself).
Was du brauchst
Start by turning the device port side up.
With the plastic opening tool, pry along the edges of the case.
When you hear the case snap-out of its fitted grooves, slowly slide the board assembly out of the case.
Grab the mini USB port and align it with the appropriate metal docks on the motherboard.
Solder together the four corners of the mini USB to the appropriate metal pieces on the motherboard.
To reassemble your device, follow these instructions in reverse order from step 8.
8 weitere Nutzer:innen haben diese Anleitung absolviert.
