Zum Hauptinhalt wechseln
Western Digital My Book Mini USB Port Replacement
Was du brauchst
  1. Western Digital My Book Mini USB Port Replacement, Mini USB Port: Schritt 1, Bild 1 von 3 Western Digital My Book Mini USB Port Replacement, Mini USB Port: Schritt 1, Bild 2 von 3 Western Digital My Book Mini USB Port Replacement, Mini USB Port: Schritt 1, Bild 3 von 3
    • Start by turning the device port side up.
    • With the plastic opening tool, pry along the edges of the case.
    • When you hear the case snap-out of its fitted grooves, slowly slide the board assembly out of the case.
  2. Western Digital My Book Mini USB Port Replacement: Schritt 2, Bild 1 von 1
    • Gently pull the three pronged, clear plastic piece from the rubber holder.
  3. Western Digital My Book Mini USB Port Replacement: Schritt 3, Bild 1 von 1
    • Unscrew the two screws from the motherboard.
  4. Western Digital My Book Mini USB Port Replacement: Schritt 4, Bild 1 von 1
    • Remove all the rubber pieces from the four corners to unhinge the motherboard.
  5. Western Digital My Book Mini USB Port Replacement: Schritt 5, Bild 1 von 1
    • Remove the motherboard.
    • Set aside in a safe anti-static location.
  6. Western Digital My Book Mini USB Port Replacement: Schritt 6, Bild 1 von 1
    • Grab the mini USB port and align it with the appropriate metal docks on the motherboard.
  7. Western Digital My Book Mini USB Port Replacement: Schritt 7, Bild 1 von 1
    • Soldering irons can get HOT! Do not touch the iron tip, make sure it cools down for a good 30 minutes before touching the tip.
    • Start heating up the Soldering Iron, may take about 10–15 mins.
  8. Western Digital My Book Mini USB Port Replacement: Schritt 8, Bild 1 von 1
    • Solder together the four corners of the mini USB to the appropriate metal pieces on the motherboard.
    • Make sure the USB is firmly attached to the motherboard.
Abschluss
To reassemble your device, follow these instructions in reverse order from step 8.
8 weitere Personen haben diese Anleitung absolviert.
Colorado Springs, Team 1-2, Mcmichael SU 2015 Mitglied von Colorado Springs, Team 1-2, Mcmichael SU 2015
UCCS-MCMICHAEL-SU15S1G2
2 Mitglieder
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 16
Letzte 30 Tage: 64
Insgesamt: 16,851
