Zum Hauptinhalt wechseln
Wexford CT-166TF Air Filter Casing Replacement
Was du brauchst
  1. Wexford CT-166TF Air Filter Casing Replacement, Air Filter Casing: Schritt 1, Bild 1 von 1
    • Using a plastic opening tool, remove the four small foam pieces on the bottom of the fan.
  2. Wexford CT-166TF Air Filter Casing Replacement: Schritt 2, Bild 1 von 3 Wexford CT-166TF Air Filter Casing Replacement: Schritt 2, Bild 2 von 3 Wexford CT-166TF Air Filter Casing Replacement: Schritt 2, Bild 3 von 3
    • Remove the four screws that were uncovered in the previous step.
    • Remove the bottom cover using a spudger if needed.
  3. Wexford CT-166TF Air Filter Casing Replacement: Schritt 3, Bild 1 von 1
    • Remove the five screws that can be seen by aligning the base and the fan.
  4. Wexford CT-166TF Air Filter Casing Replacement: Schritt 4, Bild 1 von 2 Wexford CT-166TF Air Filter Casing Replacement: Schritt 4, Bild 2 von 2
    • Stand the fan upright. Locate and remove the two screws near the top.
  5. Wexford CT-166TF Air Filter Casing Replacement: Schritt 5, Bild 1 von 2 Wexford CT-166TF Air Filter Casing Replacement: Schritt 5, Bild 2 von 2
    • Locate and remove the two bottom screws.
  6. Wexford CT-166TF Air Filter Casing Replacement: Schritt 6, Bild 1 von 1
    • Remove the back casing by pulling it away from the front casing.
  7. Wexford CT-166TF Air Filter Casing Replacement: Schritt 7, Bild 1 von 2 Wexford CT-166TF Air Filter Casing Replacement: Schritt 7, Bild 2 von 2
    • Remove the two screws attaching the motor to the front casing.
  8. Wexford CT-166TF Air Filter Casing Replacement: Schritt 8, Bild 1 von 2 Wexford CT-166TF Air Filter Casing Replacement: Schritt 8, Bild 2 von 2
    • Remove the two middle screws connecting the air filter casing to the front casing.
    • Remove the front casing.
  9. Wexford CT-166TF Air Filter Casing Replacement: Schritt 9, Bild 1 von 1
    • Remove the four remain screws holding the air filter casing together
  10. Wexford CT-166TF Air Filter Casing Replacement: Schritt 10, Bild 1 von 2 Wexford CT-166TF Air Filter Casing Replacement: Schritt 10, Bild 2 von 2
    • Put the new air filter casing in place after cleaning the filter.
    • Repeat steps 1-9 in reverse order to properly put back together the fan.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
UW Tacoma, Team S3-G4, Liner Spring 2017 Mitglied von UW Tacoma, Team S3-G4, Liner Spring 2017
UWT-LINER-S17S3G4
4 Mitglieder
3 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 6
Insgesamt: 634
