Zum Hauptinhalt wechseln
Wexford CT-166TF Plastic Casing Replacement
Was du brauchst
  1. Wexford CT-166TF Plastic Casing  Replacement, Settings Knob: Schritt 1, Bild 1 von 1
    • Locate the knob at the top of the fan.
  2. Wexford CT-166TF Plastic Casing  Replacement: Schritt 2, Bild 1 von 1
    • Remove the knob by gripping it and pulling straight up. Use a spudger if it is difficult to grip.
    • When reassembling, be sure to align the bottom of the new knob and the turning mechanism in the fan before pushing down.
  3. Wexford CT-166TF Plastic Casing  Replacement, Plastic Casing: Schritt 3, Bild 1 von 1
    • Using the plastic opening tool, turn the device over and remove the black plastic covers over the four screw holes.
  4. Wexford CT-166TF Plastic Casing  Replacement: Schritt 4, Bild 1 von 2 Wexford CT-166TF Plastic Casing  Replacement: Schritt 4, Bild 2 von 2
    • Remove the four screws underneath the plastic covers.
  5. Wexford CT-166TF Plastic Casing  Replacement: Schritt 5, Bild 1 von 2 Wexford CT-166TF Plastic Casing  Replacement: Schritt 5, Bild 2 von 2
    • Remove 5 smaller screws visible through small holes between the base and the casing.
  6. Wexford CT-166TF Plastic Casing  Replacement: Schritt 6, Bild 1 von 2 Wexford CT-166TF Plastic Casing  Replacement: Schritt 6, Bild 2 von 2
    • Remove four screws on the back, two near the top and two near the bottom.
  7. Wexford CT-166TF Plastic Casing  Replacement: Schritt 7, Bild 1 von 1
    • Pull off the back casing.
  8. Wexford CT-166TF Plastic Casing  Replacement: Schritt 8, Bild 1 von 2 Wexford CT-166TF Plastic Casing  Replacement: Schritt 8, Bild 2 von 2
    • Remove the 2 screws that attach the front part of the casing to the motor.
  9. Wexford CT-166TF Plastic Casing  Replacement: Schritt 9, Bild 1 von 2 Wexford CT-166TF Plastic Casing  Replacement: Schritt 9, Bild 2 von 2
    • Remove the two middle screws attaching the black plastic cover to the front .
  10. Wexford CT-166TF Plastic Casing  Replacement: Schritt 10, Bild 1 von 1
    • Remove the two screws attached to the white bar near the red light on the top of the front casing.
  11. Wexford CT-166TF Plastic Casing  Replacement: Schritt 11, Bild 1 von 1
    • Remove the two screws keeping the button attached to the top of the casing.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
UW Tacoma, Team S3-G4, Liner Spring 2017 Mitglied von UW Tacoma, Team S3-G4, Liner Spring 2017
UWT-LINER-S17S3G4
4 Mitglieder
3 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 405
