Zum Hauptinhalt wechseln
Wheelbarrow Handle Replacement
Was du brauchst
  1. Wheelbarrow Handle Replacement, Handle: Schritt 1, Bild 1 von 3 Wheelbarrow Handle Replacement, Handle: Schritt 1, Bild 2 von 3 Wheelbarrow Handle Replacement, Handle: Schritt 1, Bild 3 von 3
    • Remove the screws from beneath the handles to detach them from the wheelbarrow.
  2. Wheelbarrow Handle Replacement: Schritt 2, Bild 1 von 3 Wheelbarrow Handle Replacement: Schritt 2, Bild 2 von 3 Wheelbarrow Handle Replacement: Schritt 2, Bild 3 von 3
    • Measure and record the following dimensions of the wheelbarrow handle:
    • Length,
    • Width,
    • and Thickness.
    • Use the recorded dimensions of the wheelbarrow hand to purchase a new handle.
  3. Wheelbarrow Handle Replacement: Schritt 3, Bild 1 von 1
    • Align the ends and sides of the old handle with new handle.
    • Use a bolt from the wheelbarrow and a hammer to mark the new handle with the location of the old handle's holes.
  4. Wheelbarrow Handle Replacement: Schritt 4, Bild 1 von 1
    • Use the marked locations from Step 4 to drill holes with the 5/16 drill bit.
  5. Wheelbarrow Handle Replacement: Schritt 5, Bild 1 von 3 Wheelbarrow Handle Replacement: Schritt 5, Bild 2 von 3 Wheelbarrow Handle Replacement: Schritt 5, Bild 3 von 3
    • Turn the wheelbarrow shell on its side and put the bolts though the shell and handle.
    • Attach the legs, axel assembly, and wheel guard to the shell and handles.
    • Keep all screws loose until all pieces are in place.
    • Tighten all screws.
    • If you are unsure how to reassemble your wheelbarrow, there could be assembly instructions for your wheelbarrow on the company website from which you purchased your wheelbarrow.
Abschluss
To drill the holes, you could use a drill press instead of a cordless drill to ensure the perpendicularity of the holes being drilled.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
UMass Dartmouth, Team S1-G2, Sinclaire Spring 2021 Mitglied von UMass Dartmouth, Team S1-G2, Sinclaire Spring 2021
UMASSD-SINCLAIRE-S21S1G2
1 Mitglied
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 16
Letzte 7 Tage: 56
Letzte 30 Tage: 217
Insgesamt: 3,335
