Einleitung
Manufacturer Whirlpool: USSPA, model Taurus and others.
Change Gecko pressure switch
Was du brauchst
Cut off the cable ties
Peel off the rubber
Pull off the electrical contacts
It doesn't matter which way around the contacts are reconnected during assembly
Unscrew the pressure switch with an open-end wrench
Check whether there is any dirt in the openings of the pressure switch and the holder. If necessary, remove the dirt.
Follow these steps in reverse order to reassemble your device
100%
oldturkey03 hilft uns, die Welt in Ordnung zu bringen! Wie kann ich mithelfen?
Hier starten ›
