Zum Hauptinhalt wechseln
Whirlpool WGD4800XQ Thermal Fuse Replacement
Was du brauchst
  1. Whirlpool WGD4800XQ Thermal Fuse Replacement, Thermal Fuse: Schritt 1, Bild 1 von 1
    • Unplug the dryer from the power outlet.
  2. Whirlpool WGD4800XQ Thermal Fuse Replacement: Schritt 2, Bild 1 von 2 Whirlpool WGD4800XQ Thermal Fuse Replacement: Schritt 2, Bild 2 von 2
    • Unscrew the backplate by rotating each screw counterclockwise with a ratchet and 8mm socket.
    • The screws are located around the edges of the backplate.
    • The backplate is a heavy object. Hold the backplate while removing the screws or get assistance. Dropping the backplate can cause injury or break the gas pipe.
  3. Whirlpool WGD4800XQ Thermal Fuse Replacement: Schritt 3, Bild 1 von 1
    • Lift the backplate off of the dryer.
  4. Whirlpool WGD4800XQ Thermal Fuse Replacement: Schritt 4, Bild 1 von 1
    • Pull out the blue terminal cables on the thermal fuse with a needle nose plier.
    • Keep track of what terminal fuse goes on top and bottom.
  5. Whirlpool WGD4800XQ Thermal Fuse Replacement: Schritt 5, Bild 1 von 1
    • Remove the screw from the thermal fuse with the ratchet and 8mm socket.
  6. Whirlpool WGD4800XQ Thermal Fuse Replacement: Schritt 6, Bild 1 von 1
    • Place the new thermal fuse and secure the screw with the ratchet and 8 mm socket.
  7. Whirlpool WGD4800XQ Thermal Fuse Replacement: Schritt 7, Bild 1 von 1
    • Insert the blue terminal cables to the thermal fuse with a needle nose plier.
  8. Whirlpool WGD4800XQ Thermal Fuse Replacement: Schritt 8, Bild 1 von 2 Whirlpool WGD4800XQ Thermal Fuse Replacement: Schritt 8, Bild 2 von 2
    • Put the back plate on the dryer.
    • If possible, have someone hold it up to align all the holes on the backplate and dryer while you use the ratchet and 8 mm socket to replace the screws.
  9. Whirlpool WGD4800XQ Thermal Fuse Replacement: Schritt 9, Bild 1 von 1
    • Connect the dryer to the power outlet.
Ziellinie
Eine weitere Person hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 22
Letzte 30 Tage: 61
Insgesamt: 501
