Einleitung
Suspension springs maintain your washing machine's stability similar to automotive shock absorbers. If damaged, faulty, or worn-out, your appliance will vibrate or shake more than usual. If you need to replace your Whirlpool WTW4800XQ2’s suspension springs, this guide will show you how to replace them. You can buy this component in home improvement stores, or through online shops such as Amazon.
Please do note that this guide may not work on other washing machine models. Also be sure to unplug your machine from the outlet before starting this guide.
Was du brauchst
Use an 1/4 inch nut driver to remove the four 9.5 mm hex screws on the back of the machine that secure the upper machine loading lid and console.
Remove the two brackets on the back by tilting them slightly upwards and then outwards.
Remove the 9.5 mm hex screw securing the console wiring cover with an 1/4 inch nut driver.
Remove the wiring cover by opening by and sliding it out.
Gently pull the upper machine loading lid towards you to the to release the front latch mechanism.
Hold the corner suspension spring (inside the machine) and lift it to release the end plastic joint.
Once the joint is in the air, rotate counterclockwise and push down to release the rod from the joint lock mechanism.
Lift the corner of the machine and remove the rod from the bottom of the machine.
Lower the machine slowly.
Lift the rod and pass it through the upper joint bushing hole to secure.
Insert the rod through the suspension joint and make sure it locks in the correct slot.
Eine weitere Person hat diese Anleitung absolviert.
2 Kommentare
Es mas fácil acostar la lavadora hacia un lado
Yes, it's much better to set the washer on its side. There is a plastic bushing at the bottom of the washer that can be removed by pressing the locking tabs with your fingers and then the spring rod can be removed and replaced easily.
