Einleitung
Zu Schritt 1 der Anleitung ↓Das häufigste Problem bei der Verwendung der Oculus Quest 2 ist, dass die Controller driften und sich der Joystick des Controllers bei geringem Druck von selbst bewegt. Um die Sicherheit deines Quest 2 Controllers zu gewährleisten, habe ich hier eine Anleitung erstellt, in der erklärt wird, wie du den WD-40 Specialist Kontaktreiniger sicher bei dir zu Hause anwenden kannst.
Was du brauchst
Werkzeuge
Entferne die Batterieabdeckung vom Controller.
Entferne die Batterie.
Wackle den Joystick kreisförmig herum, um das Produkt zu verteilen.
Klicke ein paar Mal auf den Joystick.
14 weitere Personen haben diese Anleitung absolviert.
100%
Hier starten ›
8 Kommentare zur Anleitung
In the article you warn the user:
"It's important to use WD-40 specialist contact cleaner instead of the regular WD-40. It will break the controller if you use the wrong can."
Are you referring to the "WD-40 Specialist ELECTRICAL Contact Cleaner" or just the "WD-40 Specialist Contact Cleaner?"
They're apparently two different products, with the former coming in a black/dark gray can (at twice the price) and the latter coming in the dark blue can that WD-40 has traditionally come in, and I don't want to pick up the wrong product for this.
Thanks for your time!
I feel that it being an electronic that it will use the electronic contact cleaner.
https://www.wd40.com/products/contact-cl... - The page indicates that they changed the appearance of the can, not the formulation. The two products you describe are the same one.
B and Y buttons no longer work after I used this method and fixed the stick drift.
Did not really work, didn’t even break the controller either, I should probably try again or something, also when I used the normal WD-40 it did not break anything but I am still suggesting to use the WD-40 specialist ELECTRICAL contact cleaner, have a nice day mate
