Zum Hauptinhalt wechseln
Wii Balance Board Battery Case Replacement
Was du brauchst
  1. Wii Balance Board Battery Case Replacement, Unscrewing the Foot Cover: Schritt 1, Bild 1 von 1
    • Flip device upside-down so the plastic white board is facing the ground.
    • Locate the four feet in the corners of the Balance Board.
    • Unscrew the three 12.7 mm Phillips screws from each foot cover.
  2. Wii Balance Board Battery Case Replacement, Removing the Foot Cover: Schritt 2, Bild 1 von 1
    • Remove the gray plastic ring from the actual foot by lifting it up.
  3. Wii Balance Board Battery Case Replacement, Removing the Foot: Schritt 3, Bild 1 von 1
    • Separate the loose foot from the device by lifting it up.
  4. Wii Balance Board Battery Case Replacement, Removing the Additional Feet: Schritt 4, Bild 1 von 1
    • Repeat steps two and three on the remaining four feet.
  5. Wii Balance Board Battery Case Replacement, Unscrewing the Back Cover: Schritt 5, Bild 1 von 1
    • Unscrew the ten 12.7 mm Phillips #1 screws.
  6. Wii Balance Board Battery Case Replacement, Removing the Back Cover: Schritt 6, Bild 1 von 1
    • Lift off the gray back cover.
  7. Wii Balance Board Battery Case Replacement, Battery Compartment: Schritt 7, Bild 1 von 2 Wii Balance Board Battery Case Replacement, Battery Compartment: Schritt 7, Bild 2 von 2
    • Locate the gray battery compartment.
    • Push the tab on the bottom and lift up completely to remove the cover to the batteries.
  8. Wii Balance Board Battery Case Replacement, Removing the Battery Case: Schritt 8, Bild 1 von 1
    • Unscrew the two 6.35 mm Phillips #1 screws.
    • Slide the battery case out.
Abschluss
16 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team 13-8, Forte Fall 2014 Mitglied von Cal Poly, Team 13-8, Forte Fall 2014
CPSU-FORTE-F14S13G8
5 Mitglieder
15 Anleitungen geschrieben
14 Kommentare
I unscrewed everything, but were do i find a replacement battery compartent?
Olivia C - Antwort
Then what do you do after you remove the battery case?
CRAIG WIKMAN - Antwort
Is there a way to open the top of the board by sliding or lifting the top? I bought a gently used wii fit. The lady who sold it to me very quickly opened the top of the board from the centre seam to show me the instruction manual and I think hook up cables. I cannot, for the life of me figure out how she did it! Any ideas or technical wizardry you can share?
Frustrated in Canada!
Pam Murray - Antwort
u rock - it totally worked
scottydecept - Antwort
Why tell to remove all those parts and then there's no replacement battery board
Valerie Triplin - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 12
Letzte 7 Tage: 66
Letzte 30 Tage: 267
Insgesamt: 41,661
