Zum Hauptinhalt wechseln
Wii Balance Board Frame Replacement
Was du brauchst
  1. Wii Balance Board Frame Replacement, Unscrewing the Foot Cover: Schritt 1, Bild 1 von 1
    • Flip device upside-down so the plastic white board is facing the ground.
    • Locate the four feet in the corners of the Balance Board.
    • Unscrew the three 12.7 mm Phillips screws from each foot cover.
  2. Wii Balance Board Frame Replacement, Removing the Foot Cover: Schritt 2, Bild 1 von 1
    • Remove the gray plastic ring from the actual foot by lifting it up.
  3. Wii Balance Board Frame Replacement, Removing the Foot: Schritt 3, Bild 1 von 1
    • Separate the loose foot from the device by lifting it up.
  4. Wii Balance Board Frame Replacement, Removing the Additional Feet: Schritt 4, Bild 1 von 1
    • Repeat steps two and three on the remaining four feet.
  5. Wii Balance Board Frame Replacement, Unscrewing the Back Cover: Schritt 5, Bild 1 von 1
    • Unscrew the ten 12.7 mm Phillips #1 screws.
  6. Wii Balance Board Frame Replacement, Removing the Back Cover: Schritt 6, Bild 1 von 1
    • Lift off the gray back cover.
  7. Wii Balance Board Frame Replacement, Battery Compartment: Schritt 7, Bild 1 von 2 Wii Balance Board Frame Replacement, Battery Compartment: Schritt 7, Bild 2 von 2
    • Locate the gray battery compartment.
    • Push the tab on the bottom and lift up completely to remove the cover to the batteries.
  8. Wii Balance Board Frame Replacement, Removing the Battery Case: Schritt 8, Bild 1 von 1
    • Unscrew the two 6.35 mm Phillips #1 screws.
    • Slide the battery case out.
  9. Wii Balance Board Frame Replacement, Unscrewing the Frame: Schritt 9, Bild 1 von 1
    • Unscrew the four 12.7 mm #1 screws.
  10. Wii Balance Board Frame Replacement, Removing the Frame: Schritt 10, Bild 1 von 1
    • Lift the frame, circuit board, and power supply out of the front case. These components are all connected.
  11. Wii Balance Board Frame Replacement, Removing the Power Supply: Schritt 11, Bild 1 von 1
    • Lift out the power supply. It is not screwed in.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Cory Olson
891 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 13-8, Forte Fall 2014 Mitglied von Cal Poly, Team 13-8, Forte Fall 2014
CPSU-FORTE-F14S13G8
5 Mitglieder
15 Anleitungen geschrieben
Ein Kommentar
Top Anleitung, aber wo kann ich die Platine herbekommen? Danke!!!
Dominik - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 9
Letzte 30 Tage: 35
Insgesamt: 2,924
