Einleitung
Use this guide to replace the back panel on your Nintendo Wii U GamePad.
Was du brauchst
Face the GamePad down and unscrew the two 4.7 mm Phillips #00 screws which are attached to the battery cover.
Lift up and remove the battery cover.
With your finger on the battery connector, pull downwards toward the base of the GamePad to disconnect it.
Pull upwards from the bottom of the battery to release it.
Remove the ten 8.9mm Tri-wing Y1 screws hidden underneath square stickers.
Lift up the back plate.
Unplug the connector that connects the back plate to the motherboard.
Remove the back panel.
12 weitere Personen haben diese Anleitung absolviert.
2 Kommentare zur Anleitung
and the front?
