Zum Hauptinhalt wechseln
Wii U GamePad Outer Case Replacement
Was du brauchst
  1. Wii U GamePad Outer Case Replacement, Battery: Schritt 1, Bild 1 von 2 Wii U GamePad Outer Case Replacement, Battery: Schritt 1, Bild 2 von 2
    • Face the GamePad down and unscrew the two Phillips #00 screws which are attached to the battery cover.
    • Lift up and remove the battery cover.
  2. Wii U GamePad Outer Case Replacement: Schritt 2, Bild 1 von 3 Wii U GamePad Outer Case Replacement: Schritt 2, Bild 2 von 3 Wii U GamePad Outer Case Replacement: Schritt 2, Bild 3 von 3
    • With your finger on the battery connector, pull downwards toward the base of the GamePad to disconnect it.
    • Pull upwards from the bottom of the battery to release it.
  3. Wii U GamePad Outer Case Replacement, Outer Case: Schritt 3, Bild 1 von 3 Wii U GamePad Outer Case Replacement, Outer Case: Schritt 3, Bild 2 von 3 Wii U GamePad Outer Case Replacement, Outer Case: Schritt 3, Bild 3 von 3
    • Remove the ten 8.9mm Tri-wing Y1 screws hidden underneath square stickers.
    • Lift up the back plate.
    • The back plate is still connected by a cable to the motherboard.
  4. Wii U GamePad Outer Case Replacement: Schritt 4, Bild 1 von 2 Wii U GamePad Outer Case Replacement: Schritt 4, Bild 2 von 2
    • Unplug the connector that connects the back plate to the motherboard.
    • Remove the back plate.
Abschluss
11 weitere Nutzer:innen haben diese Anleitung absolviert.
Kim Arre
4.918 Reputation
8 Anleitungen geschrieben
Cal Poly, Team 17-20, Forte Winter 2013 Mitglied von Cal Poly, Team 17-20, Forte Winter 2013
CPSU-FORTE-W13S17G20
5 Mitglieder
38 Anleitungen geschrieben
2 Kommentare
This is either incomplete or mistitled - it is a currently a back plate replacement guide.
At the conclusion of this how-to/walkthrough, most of the GamePad's hardware is still attached to the front plate, one half of the outer case.
Elijah - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 6
Letzte 7 Tage: 23
Letzte 30 Tage: 110
Insgesamt: 14,609
