Was du brauchst
Pry off the motherboard after removing the ribbon cables and screws, Be careful, as there are wires on either side of the bottom of the board.
After removing the speaker from the top, flip the phone over and apply heat evenly across the display. Using a suction cup carefully lift off the display
To reassemble your device, follow these instructions in reverse order. Make sure to add the included adhesive.
Eine weitere Person hat diese Anleitung absolviert.
