Zum Hauptinhalt wechseln
Window Operator Link Replacement
Was du brauchst
  1. Window Operator Link Replacement, Link: Schritt 1, Bild 1 von 2 Window Operator Link Replacement, Link: Schritt 1, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Flathead 4 mm Screwdriver
    $5.49
    Kaufen
    • Remove the four (4) window clips that holds the screen.
    • Your amount of window clips may vary depending on the size of your window.
    • Use the Flathead 4 mm Screwdriver to loosen the clip. The clip doesn't need to be removed.
    • Remove the screen and put it aside.
  2. Window Operator Link Replacement: Schritt 2, Bild 1 von 3 Window Operator Link Replacement: Schritt 2, Bild 2 von 3 Window Operator Link Replacement: Schritt 2, Bild 3 von 3
    Large Needle Nose Pliers
    Kaufen
  3. Window Operator Link Replacement: Schritt 3, Bild 1 von 3 Window Operator Link Replacement: Schritt 3, Bild 2 von 3 Window Operator Link Replacement: Schritt 3, Bild 3 von 3
    • Using the Phillips #2 Screwdriver , remove the two bolts that are holding the operator into the window frame.
    • Behind the window, you will have one self retaining nut per bolt.
    • In some cases, you will need to play with the operator in order to take it out due to the small tolerances in the window.
  4. Window Operator Link Replacement: Schritt 4, Bild 1 von 3 Window Operator Link Replacement: Schritt 4, Bild 2 von 3 Window Operator Link Replacement: Schritt 4, Bild 3 von 3
    Metal Spudger
    $2.99
    Kaufen
  5. Window Operator Link Replacement: Schritt 5, Bild 1 von 3 Window Operator Link Replacement: Schritt 5, Bild 2 von 3 Window Operator Link Replacement: Schritt 5, Bild 3 von 3
    Kaufen
    • Once the warped or broken link is removed, follow the Step 4 in reverse order.
    • You may use the Large Needle Nose Pliers to force the e-clip into place.
Abschluss
To reassemble your device, follow from step three (3) to one (1) in reverse order.
Alondra M. Soto Vega
121 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 41
Insgesamt: 845
