Zum Hauptinhalt wechseln
Window/door alarm MC06-1 - Making it beep again
Was du brauchst
  1. Window/door alarm MC06-1 - Making it beep again, My alarm: Schritt 1, Bild 1 von 2 Window/door alarm MC06-1 - Making it beep again, My alarm: Schritt 1, Bild 2 von 2
    • This is a beautiful not-alarming alarm
  2. Window/door alarm MC06-1 - Making it beep again, Getting inside the alarm: Schritt 2, Bild 1 von 1
    • There is a screw hidden underneath the adhesive strip. Screw it open to get in
  3. Window/door alarm MC06-1 - Making it beep again, Batteries: Schritt 3, Bild 1 von 2 Window/door alarm MC06-1 - Making it beep again, Batteries: Schritt 3, Bild 2 von 2
    • Remove the batteries so you won't frighten yourself by a suddenly-working alarm (or break the alarm)
  4. Window/door alarm MC06-1 - Making it beep again, Connection to the sound: Schritt 4, Bild 1 von 2 Window/door alarm MC06-1 - Making it beep again, Connection to the sound: Schritt 4, Bild 2 von 2
    • The wires weren't soldered good enough to make a sound. I applied a bit of fresh solder on the indicated places to make it work again
    • This will definitely wake me up when there's someone opening my door! Fixed
Abschluss
Anke
123 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 7
Insgesamt: 89
