Zum Hauptinhalt wechseln
Windsor Willow Derailleur Replacement
Was du brauchst
  1. Windsor Willow Derailleur Replacement, Chain: Schritt 1, Bild 1 von 1
    • The chain connects the crank arm to the gear cluster on the back wheel.
  2. Windsor Willow Derailleur Replacement: Schritt 2, Bild 1 von 1
    • On the chain, locate the master link. It is a lighter gray than the other links of the chain. This is how you can break the chain for easier removal.
  3. Windsor Willow Derailleur Replacement: Schritt 3, Bild 1 von 2 Windsor Willow Derailleur Replacement: Schritt 3, Bild 2 von 2
    • To separate the Master Link, hold the left side of the link in your left hand and the link to the right in your right hand. Push the two links together to enable the release. Pull the links apart, one hand moving towards yourself and the other away from you. This will separate the links of the chain.
  4. Windsor Willow Derailleur Replacement: Schritt 4, Bild 1 von 1
    • Once you have separated the links of the chain, pull down on the right side of the chain as shown. Pull until the chain has been fully removed from the gears. Place the chain on a paper towel or cloth to prevent getting grease anywhere.
  5. Windsor Willow Derailleur Replacement, Rear Wheel: Schritt 5, Bild 1 von 1
    • Hold the bicycle so that the bicycle wheels rests in the air and able to stand on its own.
  6. Windsor Willow Derailleur Replacement: Schritt 6, Bild 1 von 2 Windsor Willow Derailleur Replacement: Schritt 6, Bild 2 von 2
    • Open the sidepull brakes by fully rotating the title lever on the brake upwards.
  7. Windsor Willow Derailleur Replacement: Schritt 7, Bild 1 von 2 Windsor Willow Derailleur Replacement: Schritt 7, Bild 2 von 2
    • To loosen the wheel, simply pull out the lever, away from the frame and loosen up.
  8. Windsor Willow Derailleur Replacement: Schritt 8, Bild 1 von 1
    • When the quick release is opened, the wheel is ready to remove.
  9. Windsor Willow Derailleur Replacement, Loosen the Hex Bolt and Free the Derailleur Cable: Schritt 9, Bild 1 von 1
    • Loosen the hex nut, as shown, on the side of the derailleur. This bolt plays a key role in securing the derailleur cable which we will need to cut in step two.
  10. Windsor Willow Derailleur Replacement, Cut the Derailleur Cable: Schritt 10, Bild 1 von 3 Windsor Willow Derailleur Replacement, Cut the Derailleur Cable: Schritt 10, Bild 2 von 3 Windsor Willow Derailleur Replacement, Cut the Derailleur Cable: Schritt 10, Bild 3 von 3
    • Using a pair of wire cutters, locate the end of the derailleur cable. Cut the wire just below the cap, cutting off the metal end piece.
  11. Windsor Willow Derailleur Replacement, Remove Derailleur from Frame: Schritt 11, Bild 1 von 2 Windsor Willow Derailleur Replacement, Remove Derailleur from Frame: Schritt 11, Bild 2 von 2
    • Using a hex key wrench, unscrew the bolt that fastens the derailleur to the bike frame. The derailleur should come off easily because it is no longer fastened to the bike and the derailleur cable can easily slip out.
Abschluss
Ethan
201 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 10-6, Banghart Winter 2017 Mitglied von Cal Poly, Team 10-6, Banghart Winter 2017
CPSU-BANGHART-W17S10G6
5 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 11
Insgesamt: 123
