Zum Hauptinhalt wechseln
Windsor Willow Rear Wheel Replacement
  1. Windsor Willow Rear Wheel Replacement, Chain: Schritt 1, Bild 1 von 1
    • The chain connects the crank arm to the gear cluster on the back wheel.
  2. Windsor Willow Rear Wheel Replacement: Schritt 2, Bild 1 von 1
    • On the chain, locate the master link. It is a lighter gray than the other links of the chain. This is how you can break the chain for easier removal.
  3. Windsor Willow Rear Wheel Replacement: Schritt 3, Bild 1 von 2 Windsor Willow Rear Wheel Replacement: Schritt 3, Bild 2 von 2
    • To separate the Master Link, hold the left side of the link in your left hand and the link to the right in your right hand. Push the two links together to enable the release. Pull the links apart, one hand moving towards yourself and the other away from you. This will separate the links of the chain.
  4. Windsor Willow Rear Wheel Replacement: Schritt 4, Bild 1 von 1
    • Once you have separated the links of the chain, pull down on the right side of the chain as shown. Pull until the chain has been fully removed from the gears. Place the chain on a paper towel or cloth to prevent getting grease anywhere.
  5. Windsor Willow Rear Wheel Replacement, Rear Wheel: Schritt 5, Bild 1 von 1
    • Hold the bicycle so that the bicycle wheels rests in the air and able to stand on its own.
  6. Windsor Willow Rear Wheel Replacement: Schritt 6, Bild 1 von 2 Windsor Willow Rear Wheel Replacement: Schritt 6, Bild 2 von 2
    • Open the sidepull brakes by fully rotating the title lever on the brake upwards.
  7. Windsor Willow Rear Wheel Replacement: Schritt 7, Bild 1 von 2 Windsor Willow Rear Wheel Replacement: Schritt 7, Bild 2 von 2
    • To loosen the wheel, simply pull out the lever, away from the frame and loosen up.
  8. Windsor Willow Rear Wheel Replacement: Schritt 8, Bild 1 von 1
    • When the quick release is opened, the wheel is ready to remove.
Abschluss
Zin
102 Reputation
1 Anleitung geschrieben
Cal Poly, Team 10-6, Banghart Winter 2017 Mitglied von Cal Poly, Team 10-6, Banghart Winter 2017
CPSU-BANGHART-W17S10G6
5 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 4
Insgesamt: 164
