Einleitung
To complete this guide, you will need precision accuracy and some elbow grease.
Pry off the backplate by inserting a spudger or plastic opening tool into each corner and popping them open.
Un-stick the battery from the motherboard assembly with the plastic opening tool.
Schritt 6 Motherboard
Achtung: Die Schritte 6-10 stammen von einer Anleitung, die derzeit bearbeitet wird.
Locate each of the motherboard's 4 mm screws.
Remove each of the four 4 mm screws from the motherboard pictured to the left.
Use a Phillips #00 precision screwdriver.
Use the spudger to pry the instrument array from its plastic housing.
Slowly slide the spudger underneath the adhesive tape to un-sitck it.
Be careful not to harm the array of wires leading to this tape.
Remove the charging pin holster.
Clamp on the end of the holster with the tweezers and twist until it becomes detached.
Repeat for the other side.
To reassemble your device, follow these instructions in reverse order. The charging pin holster needs to be soldered back into place.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
