Einleitung
To complete this guide, you will need steady hands to remove and replace the motherboard.
Was du brauchst
Pry off the backplate by inserting a spudger or plastic opening tool into each corner and popping them open.
Un-stick the battery from the motherboard assembly with the plastic opening tool.
Remove each of the four 4 mm screws from the motherboard pictured to the left.
Use a Phillips #00 precision screwdriver.
Use the spudger to pry the instrument array from its plastic housing.
Slowly slide the spudger underneath the adhesive tape to un-sitck it.
Be careful not to harm the array of wires leading to this tape.
