Einleitung
In this guide, you are going to remove and replace your malfunctioning Wi-Fi card.
Was du brauchst
Remove the five Philips #1 screws on the panel located underneath the laptop battery.
Lift up the panel.
Use a spudger to lift the two antenna connectors from the wireless card.
Using a Philips #1 Screwdriver, remove the two screws holding the card in place.
Fast fertig!
Abschluss
