Einleitung
If your wireless LAN card is damaged or broken or you're having trouble connecting to WiFi with your laptop, replace Wireless LAN card using this guide.
Was du brauchst
Using the Phillips #1 screwdriver, remove the four 6mm screws on the back of the laptop.
Insert the plastic prying tool and pry the back panel off starting at an edge and moving your way around it.
Use the tweezers to remove the two connecting wires.
Using the Phillips #1 screwdriver, remove the two 2.5mm screws holding down the card.
